Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Restart issues, possibly hardware?
Okay so it seems only I get the weird electronics.
My iPhone 3gs was running smoothly until a couple of months ago. I was running apps and games and whatnots. But while i was reading a pdf file on quickoffice, it decided to restart itself on its own. This repeated for a while. Thinking it might be a software problem, I restored it.
Post this, it got to a point where it wouldn't even charge at all. Even if it did, it would shut off every three minutes or so. But only if used. If left alone, it would go on for the entire day. Anything above three minutes, and it restarts.
Also, how i got it to charge was to perform a hard reset every time i needed to charge the phone. It would then work okay for a while and start acting up again pretty soon.
Any help?? Please?
-Update-
So I've changed the battery, and it hasn't really solved the issue. The battery percentage stays stuck at a 100%. What do i do now?? And it still sometimes restarts on charging.
Add a comment
Most Helpful Answer
Aryan Sharma, I do not think that you have weird electronics ;-) It sounds to me that all you need is a new battery. Apple iPhones and iPods behave really erratic when the battery goes down. I would start with that and see what it does :-) good Luck
iPhone 3GS Battery Replacement
iPhone 3GS Battery
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
Score 1
Add a comment
my iphone 3gs key pad is not working
Add a comment
Add your answer
Aryan Sharma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,089
