Why won't the touch screen work unless plugged into power supply
Touch screen won't work unless plugged into power supply
Maybe there is a problem with your internal power supply (battery & wiring).
Check if your battery connector is still properly in place. If yes, you maybe have a damaged or old battery.
It could be that your battery reached the end of it’s life, and it’s not able to deliver enough power to get the screen to work.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 105
I’m assuming that the device works on battery normally aside from the touchscreen, right?
by Alec M
