0
Score
Avatar
binaryop8
Asked
horizontal 'lines' on screen, after a slight 'knock' to back
History
Hi, I recently managed to knock my phone against a low post in the street. I knocked the back of the phone whilst it was in my pocket.
I've now noticed that there 'lines' at the bottom of the screen - I assume this is possibly due to a dodgy connection to the LCD matrix?
1. Do you think it's fixable [no other visible 'damage' to the screen?
2. or is it possible damage to the logic board?
The 'lines' are on every screen and have the same colour - dark blue? They are even getting longer, though I don't use the phone now?
Thanks in advance for any help - compassion ;^)
Edited by: oldturkey03 ( ) , binaryop8 ( ) , iRobot ( )
Post Answer
0
Score
Avatar
martin
2k
Answered
Accepted Answer
PermalinkHistory
This could be caused by two things.
One - LCD connection has come loose.
This is the simple and free cause as all you have to do is take the digitiser (screen) off and re-seat the LCD connection. If this fixes the issue i would highly recommend buying some Anti-Static Kapton tape. This tape is high quality electrical tape with strong adhesive and heat tolerance.
Polyimide Tape
Two - The LCD has been damaged
This is the harder and more expensive cause as the LCD has been damaged. As per the name LCD (Liquid Crystal Display) if it is knocked or bumped hard enough it causes the "liquid" to displace itself possibly causing those horizontal lines you now see. However all you will need to do is replace the LCD and you will be good to go.
Here is a link to the part you will need to buy
Here is a link to the guide you will need to replace it if you do not know how.
Hope this helps :D
Product Image
iPhone 3G Display
LCD panel / Does not include touch portion of display or the metal backing plate. — 5 available at 29.95 each.
Product Image
Polyimide Tape
108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width. — 50+ available at 9.95 each.
0
Score
Avatar
Lewis Lane
Answered
PermalinkHistory
I had the same issue on an iPhone 4S and I fixed it by warming it up to body temperature for 30 minutes or so. The lines gradually disappeared!
Add Your Answer
Today: 2
This Week: 67
This Month: 366
All Time: 14,367
