0
Score
Avatar
mdbitne
Asked
Is my battery dead or is it the dc-in jack?
History
i have a similar problem. i have replaced my dc-in board and my battery still wont charge. it is at 0% and works fine while plugged in. i have tried resetting the pram to no avail. these are my battery stats:
Battery Installed: Yes
First low level warning: No
Full Charge Capacity (mAh): 65475
Remaining Capacity (mAh): 0
Amperage (mA): 0
Voltage (mV): 8696
Cycle Count: 65535
Edited by
Post Answer
0
Score
Avatar
nick
12.3k
Answered
PermalinkHistory
Bad battery, if it says 0 for remaining capacity, this means all the cells are drained completely
Over time, cells lose thier capacity to hold power, so you will need to change the battery at some point
You can take this pack apart and rebuild it, but this is dangerous if you don't take your time and one screw up could cause a short and a fire, so stay away from this if you aren't patient or have no clue what you are doing
Have a professional company do it if you want to rebuild the battery
Add Your Answer
