Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
81 Questions View all
Ok, so my truck will not start or turn over. I've had a lose positive
Like I was saying I'm getting juice lights work radio blinkers ect but the cluster does not respond at all other than it will show check engine light. No warning lights or gauges working. Ok it's a 03 Silverado 1500 5.3L. As of right now I'm reading 11.40 from batt to where alternator ties in down to starter constant 11.40. Would a pic/vid of what's going on in cab help, because I really suspect that what's going on with the cluster has a lot to do with it but that's just a gut feeling. I've had a loose connection on my hot for a min. The night it stoped ,it didn't really want to start and as I was driving it I noticed the security light on. Well when I got out at the store that was it all she wrote when I came out absolutely nothing idk if that has any relevance or not I have changed the terminal because I thought that might be why it wouldn't start so I changed it with a top post splice thing changed it from side post in case there was any bad corrosion or anything in there
2 Comments:
@robracer87 what is the exact model, year and engine size of your Truck?
by
03 siverado 1500 5.3L
by
Add a comment
1 Answer
Also check fuses, main or eng fuse. Put an OBD scanner on it and check for codes.
Add a comment
Add your answer
Robert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 70
