Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 Questions View all
Why won't it charge?
My dsixl turns on ok and runs fine, but it wont charge. When I plug in the wall charger the charge light does not go on. I thought that this might be a problem with the led, but a few seconds after I turn it on with it plugged in, it turns off because of a low battery, so it isnt charging because when I have it plugged in it works even with a low battery. I tried the charger in multiple outlets and tested the voltage output. There isnt a problem with the charger. Please help me.
Score 1
Add a comment
Most Helpful Answer
Check to see if your charging socket is damaged. Sometimes you can see the damage inside the power port. also check your power board as well to make sure the connectors are tight and not corroded or otherwise damaged. Check your fuses as well and make sure that they are working. Especially F2 on the underside of the battery PCB has a high rate of failure.
Nintendo DSi XL Power Board Replacement
Score 2
Add a comment
take out the thing that holds the charger in and then hook it up worked for me!
Add a comment
Add your answer
svrobots will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 19
All Time: 4,136
