0
Score
Avatar
Flo
Asked
Car stopped. Not battery
History
Have a 1998 Honda Accord LX 4 cylinder, my husband was on thehighway two days ago, the car was running fine and then it just stopped,the radio and everything was functionng, except the car stoppe Myhusband turns it on and it does start, it just won't go. We thnk is the ditributor........is this a correc analysis?
The engine runs, but the car will not move? Is it an automatic or standard? If it starts and the engine runs, it will not be the distributor.
oldturkey03,
the car is an automatic andit starts but the engine does not run
Flo,
Post Answer
Score
Avatar
oldturkey03
87.8k
Answered
PermalinkHistory
Flo, the engine runs, but the car does not drive. Sounds like you are having issues with the automatic transmission. Does the gear selector ( gear shift) feel like it normally does? It could be that the shift cable is broken or out of alignment, that the transmission oil pump is worn or binding, a stuck pressure regulator or the the transmission fluid strainer is clogged. I really think that you need to have it looked at closer by somebody. Start with the easier part, the cable and go from there. I attached some pictures to show the cable and adjustment. It should give you an idea of what to look for. I do hope that this makes sense. Let us know how it is going and good luck to you.
Score
Avatar
Dinah
Answered
PermalinkHistory
we had the same problems with our 98 Accord...turns out it was the ignition switch....quick fix.
Add Your Answer
