How do you remove stripped screws from the bottom of the phone?
The screws are stripped at the bottom of my iphone 4...how do you get them out??? :/
I use this extractor set: Precision Screw Extractor Set
thank you. :] ill try it
The extractor set is great. In a jam, if you have a cheap -mini flat head screwdriver you might be able to file down the tip to fit inside the screw head to get some torque.
if your good with power tools a Dremel is what i used to cut a slot in it for a flat head
You can try this but i must warn you to be VERY CAUTIOUS in what you are doing. I used this method and it was successful for me, but then again, it was a small screw. *I am not responsible for any damage done to your phone* :)
Ok, so i took a power drill and used it on the top screw of the EMF protection shield. The screw was stripped so I took the smallest drill bit i could find that would just fit the circumference of the screw. Then, very carefully screw into it, completely making the screw into a bowl. Next, switched directions of the drill, used a little force and went slow....next thing i know the screw is out. You can try this but just be careful and don't break anything. GOOD LUCK! Let me Know if you need anything else..
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 14,784
2 Comments
How did they get stripped?
Are they 5 point or 4 point?
by Derek Halman
someone was going to replace the screen...stripped one and lost the other and now im stuck with this problem and idk what they were
by Haley
