This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Questions View all
Question Closed
DS lite don't work after repair.
Hello,
I've repaired my DS lite (because the upper screen didn't work).
After that, I reassembled it and it doesn't work anymore (I can see the green light but it turns out one second later). I tried to tear down it a second time and reassemble again but nothing changed.
Even when I plug it to a power supply, the orange light is missing. So, do you know the problem?
Thanks for your answers.
Add a comment
Hi!
I had the exact same problem, i got the dsl up and running by checking all the ribon cabels. I guess they werent attached correctly. They have to be pushed all the way in. I still havent got the red light to work thoug :/
Anyone got an idea?
tnx in advance!
Add a comment
just try it again.. if doesn't work.. clean the ribbon tip (the copper strip at the end), with cotton buds dip in a 70% solution alcohol.. wipe it gently and then wait until it dries (about a seconds).. then put it all again..
1 Comment:
Ok, thanks. I'll check again...
by
Add a comment
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 5
All Time: 875
