Nintendo Switch screen turn on & off
Hi,
My Nintendo Switch screen turn on & off when I want to boot it.
the backlight turns on and off and turns on in a loop. The same thing happen when I plug the switch in the dock.
Hi,
I have experience in switch repair. Can you see anything on the screen? Does it go to rcm? Is your unit rcm exploitable, if yes depending on your fuses we can rebuild the nand if this is hppefully a software issue. Else I am worried it might be something
Hi,
The switch doesn't display anything, the only thing is the backlight Lightning on & off, like if the screen was trying so turn on but fail.
The switch is patched, so not exploitable.
Someone tell me that it could be the LCD Connector, what do you thing about it ?
Regards,
Since it loops even in the dock a charging volt meter might be helpful to see if it charges. Does it go to RCM at least (even tho it's patched) ? That will help us with the chip to replace. I suspect either the M92t36 either the bq(something) chip check this thread https://gbatemp.net/threads/m92t36-or-bq...
Did you ever get your switch fixed? I’m experiencing the same thing.
I am experiencing the same issue after performing several repairs. I replaced the screen, battery and right joycon rail. I will double check all my connections, leave it plugged in for a moment to hopefully charge up the new battery, and try the RCM thing. It is a day one Switch.
I will respond here if I figure anything out.
Follow up to my post from yesterday.
It turns out for my issue the ribbon cable for the LCD was just not seated properly. I guess the device will not boot without the LCD screen display cable. Obviously the backlight cable was connected as that was working.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 31
All Time: 809
