0
Score
Guenola
Asked
machine stops after filling in with water
Machine starts and fill with water then stops. if I restart the cycle it will go thru the wash and stop again at the start of the rinse cycle. I have to force the cycle few times to allow it to rinse the wash and then again force the spin cycle. at each time it stops I have the FH error on the display. the water pressure looks fine and the water comes in.
Edited by: iRobot ( ) , osvaldo and oldturkey03 ( )
4
Score
mayer
148.4k
Answered
Accepted Answer
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
