3
Score
Avatar
VesK
37
Asked
Changed batteries and it doesn't power up after that.
History
I have changed batteries in my wireless keyboard and when I wanted to turn on keyboard it couldn't be turned on? It was working fine before that. Made sure batteries are installed properly, still it can not be turned on! Help, please. Thank you!
Edited by: pollytintop, mayer, and rj713 ( ) , Brett Hartt ( )
Does it work with the old batteries put back in?
mayer,
Post Answer
10
Score
Avatar
Jensekin
111
Answered
Accepted Answer
PermalinkHistory
I found the solution on the apple forum:
Take all Batteries Out.
Roll up a small piece of Tin Foil about the size of a Pea.
Drop the Tin Foil Ball down the Battery Compartment.
Put your Batteries Back In.
You should have a Working Keyboard.
This worked for several people on here including me.
I'm still running 2 months later with my rolled up piece of Tin Foil in my Battery Compartment.
I know it sounds Crazy. That's what I first thought.
Apparently Apple did not make the + Terminal Inside the Keyboard correctly.
Try it. What have you got to lose?
thaaaaanks... it works!!!!!
heiko,
Yes, yes, yes thank you Jensekin it worked for me too!!! I'm so glad that i didn't trow it away :-)
Dutchie,
I had a keyboard that went bad because of a bleeding battery. I cleaned it up and tried to fire it up to no avail. I was real unhappy because I couldn't take it apart to get in do do more. I couldn't believe that the foil trick would work, but it did1 Your advice and an insignificant piece of foil and I have my expensive keyboard back. Wow! Thank you muchos!
Peter Moskaluk,
Thank you soo much! Worked perfectly! :D
Jonas K,
Just worked fore me too I had already replaced one keyboard! This was the first battery change on the new keyboard and it would not power up with the new batteries. I pea sized piece of foil.Instant result!thanks
martinweir,
Show 1 more comment
Score
Avatar
James
13
Answered
PermalinkHistory
Long story but explains why this pea tinfoil idea works, whilst at the same time leaving a question I hope someone else can answer . . . . . .
A few months back my wireless keyboard also just packed up completely. I couldn't work out what was wrong but it did seem that when I put the batteries into the keyboard they were sticking out further than before, so it was a bit more difficult to put the battery cover cap back on. I tried a few different things unsuccessfully and then gave up and dumped it in a drawer.
I had another go this morning and had an idea - a bad one, albeit with a postive result - to try and screw or push the battery terminal inside down into the battery compartment, in case the connection had been separated. I did this by putting double-sided sticky tape onto the handle of a wooden spoon to try and push/screw it back down. My 'ingenious' idea had an unexpected outcome in that when I pulled the spoon out I also pulled out the +positive connector from inside the keyboard, leaving the spring underneath exposed.
Now the batteries are in direct contact with the spring and the keyboard works just fine.
Clearly the tinfoil idea is a far better one than my brutal approach but what I'm a bit mystified by is the +positive on the battery can not even touch the metal connector, which is set too deep inside a plastic frame that stops it from touching it. . . . so was there something else inside that has fallen out that the pea tinfoil acts as a replacement for ?. . . . answsers on a postcard please. . . .
Score
Avatar
jaymueller
13
Answered
PermalinkHistory
Wow, it really does work. I believe that if a bad battery fuses to the bottom there, it causes the spring to breakdown....just a theory.
0
Score
Avatar
Brady Cabe
1.6k
Answered
PermalinkHistory
Bad replacement batteries?
I tried to put old batteries back in and bought new batteries 3 times, but still nothing. Thank you for your help.
VesK,
0
Score
Avatar
Evan Wang
Answered
PermalinkHistory
It works ! how amazing ~~~
Thanks ~
0
Score
Avatar
Arnaud Ehrenfeld
Answered
PermalinkHistory
That's crazy! You just make my day with my wireless keyboard which works again!! Thank you, it's brillant!
0
Score
Avatar
Dario Garzon
Answered
PermalinkHistory
batteries have acid and there is acid is around the battery compartment,this is making the electric contacts to loose continuty.
Try to clean the inside with a long piece of towelpaper humid with windex upside down, avoid to soak the towel paper, and let run fluid far the compartment, clean until it all the white colors disapears.
if you have a long metal brush, just bush the inside of the compartment. wash the aluminum cover with water and it will be done!.
very easy :D
Next time use quality batteries to avoid spills. this usually happends when you stop using your keyboard for a long time.
If you want to avoid this to happend, remove batteries before to store.
Edited by: Dario Garzon ( )
0
Score
Avatar
roro
Answered
PermalinkHistory
yes yes yes!!! i too had the same issue and had this piece of advice not worked, it would've gone into the trash. my keyboard worked after battery leak. So so happy, thank you!!!
01-31-2012 from sunny LA, CA :) GO LAKERS!!!
0
Score
Avatar
Rainer Lanz
Answered
PermalinkHistory
Thanks to Jensekin (and several posters at the Apple Support Communities forums), my Apple Wireless Keyboard is now working again! It was bought in April 2008 from Amazon, so is now close to four years old, but it's still in good shape, and would have been a shame to throw away.
By the way, I had already cleaned the contacts and checked for dirt inside the barrel, not speaking of testing with several sets of batteries. I can even testify that the spring inside the barrel is still working - but obviously it isn't strong enough any more, as only the aluminium foil ball brought the keyboard back to life again.
Best wishes from frosty southern Germany.
0
Score
Avatar
michaelgor
Answered
PermalinkHistory
WOW.. found this answer via Google
thank you...it is 10/4/12 and the keyboard di not work after battery change
I tried the pea size aluminum foil and it worked perfectly. Thank you so much for posting this
0
Score
Avatar
Joan S
Answered
PermalinkHistory
It worked perfectly. I'm using the keyboard to type this thank you note.
0
Score
Avatar
Zephyr
Answered
PermalinkHistory
I was convinced mine had crapped the bed, but the tin foil trick worked like a charm! Try it - what've you got to lose! Thanks!
0
Score
Avatar
azurite
Answered
PermalinkHistory
Jenskine, thanks a lot for the info. Mine worked perfectly after following your advice.
Add Your Answer
