0
Score
Avatar
Ryan
11
Asked
Cant get screws out with #00PH
History
Ok so Im trying to get to my on/off button and the 5 screws holding the logic board down wont come out I tried to apply pressure and nothing, screws wont turn or move im just making it even harder since the tread in the screw is wearing. how can I get the screws out?
Edited by
Ok im thinking its the screwdriver set I just got. it was pretty cheap. whats the best brand to buy for the IPhones? need one with a strong magnet, noticed the last two I tried were way to weak for the case screws and even worse the 2.3mm size ones. Suggestions?
Ryan,
Post Answer
Score
Avatar
Brad
4.7k
Answered
Accepted Answer
PermalinkHistory
The screws are Philips #00. Take the iPhone to the Hardware store and demo a few screwdrivers right there. Actually I have had luck at the 99cent Store they sell the cheap kits with about 10 mini screwdrivers, often two of the Philips from the kit will work perfect with the iPhone, again demo on iPhone in the store first.
Regarding magnetic screwdriver, never buy one. Take any magnet, even a refrigerator magnet, and run it along the screwdriver pulling it straight off the tip. Do it a couple of times for greater strength (will last for months). To demagnetize run the magnet the other way.
Thanks that worked! and I found a 46 piece precision tool kit for $6 steel.
Ryan,
0
Score
Avatar
Jake Devincenzi
5.2k
Answered
PermalinkHistory
If you're going to be doing any more electronics disassembly, we highly recommend our 26 Piece Bit Driver Set. It contains driver bits for all common screws for cell phone repair, as well as bits for most screws used laptops, video game consoles, and more. It has all of the common phillips sizes, torx sizes, and tons more. It even comes with a 6 month warranty if any of them break. We guarantee that it will work on your #00PH problem.
Hope this helps!
Product Image
26 Bit Driver Kit
Screwdriver kit includes almost all of the Phillips and Torx drivers we carry. — 50+ available at 14.95 each.
0
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
To get the screws out that are already messed up try this extractor set: Precision Screw Extractor Set
Product Image
4 different sized extractors to help remove fasteners with stripped heads. — 50+ available at 19.95 each.
Add Your Answer
