0
Score
Asked
Increased computer temperature - what causes it?
I upgraded my Macbook Pro 13" mid 2010 last week from the stock 250GB hard drive to http://www.amazon.co.uk/Western-Di [...] 118&sr=1-1
and the stock 2x2 GB RAM to 4x2 GB http://www.crucial.com/eu/store/pa [...] 1264BC1067
My MBP now constantly runs appr. 10 degrees Celcius hotter than before.
(I also installed Parallels and Windows XP and the temperature spikes to around 80/85 when I use it.)
It used to idle around 40-50. It rarely went above 55, even if I ran a video on VLC-player and had iTunes, Photoshop and Chrome with a bazillion tabs + a bunch of other stuff running in the background. And I'd have the laptop on a semi-soft material (a folder or a book)
Only if I had it on my lap for an extended amount of time would it get really hot. And "really hot" was max 80 C for a very limited time because the fans kicked in (max 4000 rpm)
Right now my MBP's temps are as following:
Hard drive: 40
CPU A: 65
Heatsink A: 52
Enclosure bottom: 37
Northbridge 1: 49
I'm running Chrome, iTunes and Photoshop and VLC Player idles in the background. Fans are at 2800 rpm which is appr. 800 rpm higher than what it used to before the upgrade, even with the same activity.
I just tried running VLC Player and Photoshop actively at the same time (playing a video and drawing) and the fan quickly spiked to nearly 5000 rpm. It's NEVER been that high before and I've had Photoshop, VLC Player, Chrome and iTunes running at the same time plenty of times before! The temp was 77 for CPU A and around 60 for most of the others.
Room temperature is around 22 I'd guess.
Even if the temperatures aren't that much higher it still makes a difference to the aluminium frame on my MBP. It easily gets very warm now which is a bit bothersome. I really don't like the sound of the fan at 4500 rpm so I'm a bit worried as well.
What causes it to become so warm? Do I need to swap my hard drive or my RAM back to the stock ones to get my MBP cooler or is there another solution?
Any help will be appreciated, thanks in advance
Oh! And the battery life has gone down as well.
4
Score
rj713
33.9k
Answered
Accepted Answer
The bigger hard drive and increased ram will generate more heat. You should open the computer and make sure the fan is clean and working properly. Also you might want to remove the heat sink and re-apply paste (recommend Artic Silver--sold by ifixit). Then as a last effort you might use a tray similar to the one link or better still Wal-Mart has a USB powered one for about $20. Good luck.
