Score
Avatar
Timothy Beer MD
65
Asked
iPhone 3G keeps turning off randomly, even with full charge...
History
I installed a new battery in my iPhone 3G a week ago, per ifixit's beautiful instructions. Everything went smoothly and when the phone turned on just fine after installing it. However, starting the next day, my iPhone would randomly turn completely off - even right after having charged it overnight. It might stay on working fine for 2 mins or maybe even an hour, but then, out of nowhere, boom it turns off. Sometimes I can turn it back on without plugging in the charger, sometimes I have to plug it into the charger. It's been doing this ALL the time... Now it has started happening even when it's plugged in! And each time it happens, when I turn it back on, the time/date has been reset to 7:00PM December 31, 1999. I change it to the correct time, but after it shuts down again and I restart it, there it is again 7:00PM December 31, 1999.
Does anybody have any ideas on what specifically might be the cause of this problem? I would appreciate any thoughts greatly.
Edited by: Jake Devincenzi ( ) , Timothy Beer MD ( )
You'd think it wouldn't be able to go back that far...
rab777hp,
this happened to me as well, it turned off whenever i tried to do anything! text, facebook, camera, calculator, internet.. everything! it got so bad that i am using my old phone at the moment and waiting until my contract runs out and i can get a new phone, which because of this it probably wont be an iphone!
Aimee,
This happened to me as well. I purchased the new battery and replaced it. It's worse now than it was before. It won't stay on. Keeps shutting off while I have it plugged in. HELP!
sackerlund,
nothing is working i have had this problem for 2 months now and i wouldnt be able to call 911 if my life depended on it someone helppp.
help me,
Post Answer
5
Score
Avatar
Brady Cabe
1.6k
Answered
Accepted Answer
PermalinkHistory
It almost sounds like there is a short somewhere or a loose connection. Maybe a loose screw internally? My recommendation: re-open the iPhone, remove the battery, and reinstall it. Make sure there are no loose screws and that the logic board sits nicely back on top of the battery. Put the iPhone back together and make sure everything snaps into place as it should. If you are still having issues, iFixit would be happy to send a replacement battery, just to eliminate that as an issue. Shoot me an email at that point: brady@ifixit.com
3
Score
Avatar
layfield2
37
Answered
PermalinkHistory
i am unsure of your problem but my iphone used to shut off all the time on me until i did this fix which btw i am running IOS5.0.1 firmware on my iphone so the fix may or may not be for all the firmwares but give it a go any way :) here was my solution:
hello i believe I have finally found a solution to our problem guys and girls so here i will tell you exactly what to do step by step
Step 1. Shut off IPhone Or if your phone Just randomly shut off it may even work both ways i am unsure but try it both ways so if when you see this message your phone has not randomly shut off on its own try shutting it off manually first then if it still has the problem then when it does randomly shut off do as i say.
Step 2. make sure your vibrate switch is set as ring first before you do anything else. once that is done with you are going to do this sequence: switch the vibrate switch in this patter: start off at ring->Vibrate->ring->vibrate... pause for millisecond->Ring-> vibrate then hold the power button and the round button (homebutton) as if you were going to hard reboot the iphone for about 6-8 seconds now my device when i did this part it started up with out me having to let go but for others it should start up as soon as you let go but it seemed to work the way it happened for me although my iphone rebooted after holding those buttons for 3-4 seconds and then imediatly turned off again then i tried it AGAIn and it worked that time and ever since i did this "fix" it has been working fine minus the actual battery drainage software bug for IOS 5.0.1 but it hasnt shutoff on me randomly yet and i have gotten my iphone to finally go down further then 50% so it went to about 45% before i said i needed to charge it so i could use it the next day Hope i helped
0
Score
Avatar
dafta
Answered
PermalinkHistory
by the sounds of it it's simply the on/off actual button that is corrupted/shorting [this could have been caused by damp/sweat in none use]..
chances are if you got enough time and power into the phone to update the software or firmware it will still do the same.
dafta.duck [not an expert.. just an thought]
Edited by: dafta ( )
0
Score
Avatar
jamie
Answered
PermalinkHistory
my iphone 3g keeps shutting down and im dew to sell it so i need to sort this out, but last night i went to jailbreak it with the software called green pois0n then it went in to dfu mode so i turned it on and bam this keeps happening please help.
0
Score
Avatar
ghjk
Answered
PermalinkHistory
you got out of date software you have to update your phone
0
Score
Avatar
anon99
Answered
PermalinkHistory
Hey, mine has been doing this too but I have just had a read of this. Have a look, it might help? I haven't tried it yet though;
iPhone problems can often be due to outdated system software.
An unexpected shutdown can be frustrating for an iPhone user, particularly in the middle of a call or while using the Internet. While an issue of this sort can indicate a more serious hardware problem, it is also possible that the trouble can be easily fixed with some basic system maintenance.
Sponsored Link
Data Recovery Specialists
Fast turnaround, high success rate. No data, no charge - Call today !
www.datalab.co.nz
Dead Battery
One of the most common causes of an unexpected shutdown is a drained battery. If the on-screen battery image flashes red before the screen turns off, then all your iPhone needs is a bit of juice. Power-off your iPhone and let it fully charge before turning it back on again.
Out-of-Date Software
Out-of-date software can cause system instabilities that can result in a shutdown. To solve this problem, launch iTunes on your computer. Make sure that you have the most recent version of iTunes installed. Connect your iPhone to your computer with the interface cable. Select your iPhone from the list of devices displayed within iTunes. Click "Check for Update." If updates are needed, follow the on-screen instructions.
Restore to Factory Settings
If something has gone seriously wrong with your iPhone, it may be necessary to restore it to factory settings. The downside to doing this is that all of your data and custom settings will be erased from your iPhone. While this may seem drastic, sometimes this is the best way to get your iPhone to recover. To restore your iPhone, connect it to your computer and select the "iPhone" listing within iTunes. Click "Restore" to begin the restoration process.
Get Support
If none of the other suggestions have helped you solve the problem of your iPhone shutting off, then you will need to take your iPhone into your local Apple Store. Make an appointment ahead of time with a Mac Genius to get your problem sorted out. Use the iPhone Troubleshooting Assistant webpage to help speed up the process.
Sponsored Links
Data Recovery ExpertsDatarecovery.co.nz/Recover-Now
Specialists in Computer Data Recovery. Call 0800 5678 34.
iPhone Flash Drive Appwww.macroplant.com
iExplorer 3 lets you use your iPhone & iPad as a flash drive.
Download GoodSync Todaywww.GoodSync.com
Get the award winning file syncing solution today! Free trial download
Recover SD Card Photoswww.CardRecovery.com
Memory Card Recovery Software Free Trial Download. Guaranteed!
References
Apple Support: iPhone Troubleshooting Assistant
Resources
Apple: Support Information Sheet
About the Author
Marie Cartwright began writing in 2010. Her work has appeared on various websites. Having worked previously in theater administration and Web design, Cartwright now works from her home in Northern California. She also maintains an events website geared toward the science and technology community. Cartwright studied performing arts at the University of San Francisco.
Photo Credits
Chris Hondros/Getty Images News/Getty Images
0
Score
Avatar
aditya27cs08
Answered
PermalinkHistory
My 3gs started having the same problem about 8 months ago ...
Well i finally figured out the problem .
Here it is :
The reason why your iphone is shutting down is because the battery is loosely fixed .. its not able to give continuos power to the motherboard.
Its just like you have suddenly removed your battery ..isn't it.
Just open the phone ... if you have not done that ...LEARN IT ( i take that ur phone is out of warranty) .
Its better than paying hundreds of bucks to some repair guy who will do the same thing.
Open the phone ...take out the battery , put a double sided surgical tape to fix the battery firmly to the phone .
Put the hardware back and tighten up the screws.
In my case i used quickfix.. use a powerful adhesive if you can ... it wont do any harm to the battery...
Worked for me :)
hope this can help you too.
0
Score
Avatar
david glasgow
Answered
PermalinkHistory
hi, i had the same problem.I was told to connect to itunes and do a complete restore, you will lose all your data.so best save that first if needed, but it done the trick and now have no problems with it at all
rgds
dave
0
Score
Avatar
Fredrik
Answered
PermalinkHistory
I got a variety of different problems after replacing my 3GS battery (iPhone 3GS, iOS 6.0.1). I was pretty close to trash it. But I found a way to get back to life and want to share the story. My conclusion is that is seems that the software (apps & iOS) is dependent on correct power management. With a battery replacement is that radically changed. First of all get a good replacement battery, no fake ones. You get what you pay.
After replacing the battery the indicator wasn’t correct but I could live with that. Resets (home button + sleep/off button for 10 sec) and restores via iTunes didn’t help. Then started the problems. After 2 days the phone began to shutdown using the camera/GPS or simply getting a call. Annoying, especially with a new battery.
I tried everything you can read on the net. Nothing worked, it just got worse. Cleaned every connector. Put the old battery back, didn’t work either. It was dead.
My final call was this: put in the new replacement battery and tighten all screws properly. Restore the phone from iTunes, but DO NOT, I repeat do not, restore the data from the backup from iTunes. Restore the iOS but when the iPhone reboots and iTunes will continue with coping of data (apps, calendars, music etc) ABORT that process. The data from your backup will corrupt your iPhone. Abort the process, unplug your phone and let it start up alone like a new phone. You need a clean start with a new battery.
This means that you need to download your apps again. I did that very carefully (perhaps too carefully, but I did want to know if any app corrupted my phone). I have now synchronized my calendar and contacts via iTunes but I have not restored any apps. It works flawlessly. The battery indicator is even back and correct!
I’ve got it all back: a working iPhone w/o shutdowns, a battery indicator and a new, fresh battery. Good luck with your battery replacement. ;-)
0
Score
Avatar
marc
13
Answered
PermalinkHistory
replace the on off and button flex. its shorting same thing happened to my sons phone. i changed the flex and was good to go. its not firmware related. its a short.
Add Your Answer
