A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
15 Questions View all
My laptop won't switch on, why?
When I plug my charger in the light of caps lock flashes and the light showing it's charging is also on but pressing the power does not result in my laptop switching on. Does anyone have a clue what's the problem and how to sort it out?
Add a comment
1 Answer
Try the following.
  • Remove the battery and press the power button for 30 seconds
  • With the battery removed, plug in the charging cable and check if you can boot
If that doesn’t work, your battery is dead.
2 Comments:
Didnt work. Battery probably is dead
by
You might be able to find a new battery if you search the partnumber of it on Google. Usually the partnumber is located on a sticker on the battery,
by
Add a comment
Add your answer
Hamza ahmad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 90
