Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
My iPhone 3G don't boot after restore ios 4,2,1
hello
i have restores my iphone 3g with ios 4,2,1
then phone never boots again..
i tried itunes,redsnow,snowbreeze etc..
at last i tried irecovery..
pls analyze detail and suggest me a solution
[NAND] Device ID 0x3ed5d72c
[NAND] BANKS_TOTAL 2
[NAND] BLOCKS_PER_BANK 8192
[NAND] PAGES_PER_BANK 1048576
[NAND] SECTORS_PER_PAGE 8
[NND] BYTES_PER_SPARE 216
[FTL:MSG] Apple NAND Driver <AND> RO
[FTL:MSG] FIL_Init [OK]
[FTL:MSG] BUF_Init [OK]
[FTL:MSG] FPart Init [OK]
read old style signature 0x43303035 <line:401>
[FTL:MSG] VFL Register [OK]
[FTL:MSG] VFL Init [OK]
[FTL:MSG] VFL_Open [OK]
[FTL:MSG] FTL Register [OK]
[FTL:MSG] FTL_Open [OK]
Boot Failure Count:9 Panic Fail Count:0
image validation failed but untrusted images are permitted
Etering recovery mode,starting command prompt
<Recovery> iPhone$
Score -1
1 Comment
What error no. Does iTunes give? When it says can't restore click on "more details" and this should give error no. Ie 1015 or iTunes error 29... Is this a jailbroken device you tried to restore?
by
Add a comment
Most Helpful Answer
Error 1604 is an iPhone problem that shows when you try and restore your device to a previous / backup state. The issue you have here is that iTunes will typically be unable to correctly process the various important settings that it requires to make sure the restoration processes properly, and consequently will lead the error you’re seeing to occur. Since you used the common ones already I recommend that you use iReb available here. Follow the instructions from here There is more information here Hope this helps,good luck
Score 1
Add a comment
yes. it was jailbroken before restore..
i got 1604 error in itunes..
i think phone's nand flash not reachable so i got this error
pl take care" image validation failed but untrusted images are permitted"
Add a comment
Want to restore the iPhone, the iPubsoft iPad iPhone iPod Data Recovery will be the good choice.
I knew it because I have lost my iphone contact last week, and my friend recommend it to me. This iPhone Data Recovery tool works perfect, you can't miss it.
Get more:
How to restore the iPhone data ?
Add a comment
Add your answer
ali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,129
