Score
Avatar
obleijerveld
13
Asked
What SSD is suitable for early 2008 MacBook white?
History
Hi, I would like to replace my early 2008 macbook white HDD with an SSD, or replace my optical drive with an SSD. What would be the best road to take and what type of SSD is rceommended? I know that the early 2008 MB white has a SATA I connection, but I have already replaced the original HDD with a SATA II Scorpio Blue 500 GB HDD and it works like a charm. I therefore assume that I could also go with a SATA II SSD, but I have difficulty finding info on what SSD types/brands to use as most info is on the newer unibody models and MBPs. What is your take ion this and is there already an ifixit installation manual? Cheers
Edited by
Post Answer
4
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
I'm guessing this is your machine, please give the last the figures of your serial number for exact identification.:
Apple MacBook "Core 2 Duo" 2.1 13" (White-08) Specs
Identifiers: Early 2008 - MB402LL/A* - MacBook4,1 - A1181 - 2242
If this is your machine, you will need an optical bay adapter: 9.5 mm Optical Bay SATA Hard Drive Enclosure
Product Image
9.5 mm Internal ATA Optical Bay for SATA Hard Drives — 37 available at 59.95 each.
Thank you mayer, that's right, it's a Core 2 Duo 2.1 13" A1181 Macbook. It seems that I could use the optical bay SATA HD enclosure. Do you also recommend a specific brand or type of SSD for the Macbook? The optical bay is called "SATA" enclosure, but does it also fit SATA 2 type SSDs?
obleijerveld,
Score
Avatar
Todde
13
Answered
PermalinkHistory
Sorry for the confusion, never replaced the hdd on my own before.
While obleijerveld asked for a certain model, I now can recommend the Samsung 470 Series SSD (model MZ-5PA128A), which I am using since yesterday (replaced it with my old HD with the help the ifixit hd replacement guide). I bought the 128 GB model, it has SATA II (3Gbps) but runs fine on the SATA controller in my MacBook (SATA I), just a little slower. Read Speed feels superb, while write speed for large files seems to be slow. So if you're looking for a certain model that works, that it is. Restarts Mac OS X in 15 seconds.
Sorry again for the confusion.
Torsten
Edited by
Score
Avatar
Tonci Vatavuk
13
Answered
PermalinkHistory
Have Corsair FORCE3 240Gb SSD in Macbook White early 2008 (2.4GHz). It is SATA3 but it is working great as SATA1. Before had OCZ Agile3 128GB and all was OK.
0
Score
Avatar
Todde
13
Answered
PermalinkHistory
I have the same MacBook (A1181, but 2,4GHz). So am I right, that i can't put in a SSD there?
Update
Ok, thanks! Do i need that Optical Bay Adapter if I'm going to use the original hdd slot for the ssd? I guess not?
Edited by
To avoid confusion please start a new question, and I don't see why you couldn't use an SSD.
mayer,
Two wrong guesses. START YOUR OWN QUESTION
mayer,
0
Score
Avatar
nick
12.3k
Answered
PermalinkHistory
ou can put a SSD in the computer,but i suggest doing a backup and stripping down the OSX install under Costumize to make it faster and it will limit the size of the final OSX install
Add Your Answer
