Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
White Screen of Death after Bake the iPhone
Hey guys!
Last month my iPhone´s (4) GPS started to become intermittent. Sometimes it worked, sometimes its not. As I live in Brazil and bought my phone in USA, I had nowhere to go, no warranty support, so, after tried so many restores, Cydia tweaks and long hours in open places, I decided to open the device and give it a shot, try to find some fix by myself.
I opened the iPhone and did everything I could. Disassembled it by complete (a few times) and checked every possible cause for the issue, but found nothing. So, I saw somewhere in internet about the "Oven Trick", that consists in open your phone, take out the main board (PCB) and put it in an oven for seven minutes in a temperature about 190 Cº. Theoretically, the heat can melt the solder and fix microfissures in the phone's main board. Well, seens it's true, my GPS is alive again!
Despite the GPS been' workin' fine, now I'm dealing sporadicaly with the "White Screen of Death": when the iPhone gets to sleep state and I press the "Home" or the "Sleep" button to wake it up, the screen turns to complete white, but I'm able to unlock the gadget, use the apps, play music (I can hear the sounds) and even conect with iTunes, but I can't see nothing. I'm just able to make it come back to normal opening the iPhone and cleaning the digitalizer and LCD connectors. When I do it, the iPhone works flawlessly for a few hours. If someone can help: do I'm just gettin' a bad contact and not assembled it right, or yes, I did worst and burned this part ot the PCB?
In time: hard resets doesn't help me, they do nothing but keep with the white screen. A restore was not a good option too, things didn't change. What I have to do, like I said, is open the phone and clean both connectors (digitalizer and LCD) for things go fine for a while. Last time I opened it, my camera stopped workin' too... Well, guess I'm killing softly the iPhone 4, but I'll fix it or die (I mean, kill the phone) trying!
Thanks in advance and sorry for any english mistake.
Score 1
1 Comment
Same here i forgot to take the sim out and while i was taking the motherobard off i twisted it now when it turns on its just black lines and white screen
by
Add a comment
Chosen Solution
Hey, Josh, thanks for replying, but I'm not that sure about the LCD, cause everything but the GPS was working fine before the oven (and I didn't touch on it (LCD) to remove the main board). One thing I noticed is that the issue is related to the charging process. Sometimes the phone was working great, and just after charge it or connect to iTunes, the "white screen" started to appear.
So, last night I did something that I had not done yet: let the battery completely dry and put it to a full charge. So far so good, the iPhone is working fine since then, there's just 30% of charge right now and no white screen untill this moment. Hope the issue has gone, but I'm not all confident about that, since I didn't test connecting to iTunes (I charged the phone at the wall plug). Guess I'll let the battery dry by complete again and then let it charge and sync with iTunes. Let's see what's gonna be! Thanks again for the attention.
Add a comment
could just be a damaged lcd, if you can hear the sounds and use the touch screen
Add a comment
Take the iPhone apart enough to check the screen connector and reassemble, it could just be loose and reassemble the phone, see what happens
iPhone 4 Display Assembly Replacement
Add a comment
Add your answer
pois0m will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,267
