The Blade ZTE E is an Android platform smart phone released in 2013 (Model: V956).
30 Questions View all
My zte blade x external speaker isn't working why?
Hello I bought a zte blade x it was fine for a little while. Then out of no where the external speaker stopped working. The internal speaker works. I have no cracked screen , no water damage and it hasn't fallen. I HAVE A ZTE BLADE X BUT IT ISNT IN THE DEVICES THAT I CAN SELECT
Add a comment
1 Answer
Chosen Solution
Hi @kevin7keith ,
Presumably, when you say that the external speaker is not working, you are not getting any sounds emanating from the phone’s loudspeaker, such as ringtone on an incoming call or any notification sounds, is this correct?
Have you checked that the do not disturb option has not been selected?
Can you hear the ringtone if you select a new ringtone? (see link above).
Try starting the phone in safe mode to check if you can now hear sounds from the loudspeaker.
If you can then a downloaded app is the cause of the problem. The trick is to find out which one is the cause.
If you cannot hear sounds from the loudspeaker after trying all the above, then perhaps the speaker is faulty or has become loose from the systemboard.
Here’s a link to a video which shows the dis-assembly of your phone, which may be of some help so that the phone can be inspected as to what the problem may be.
Score 3
Add a comment
Add your answer
Kevin Hall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 2,209
