0
Score
Avatar
Stu
Asked
Sim Card Tray Stuck inside
History
Iphone 4 Sim Tray stuck inside. I have tried to use Three different types of small wire type devices to push into the little hole.
Help please
Edited by
Post Answer
2
Score
Avatar
ron
37
Answered
PermalinkHistory
I've been trying and searching for hours online to get the sim tray out.
none of the solutions I found worked for me.
I already messed the sim tray hole up
(it's a Gevey tray, so I still have my original one)
I ended up figuring out a solution that no one thought about and it worked like a dream.
all what I needed was a screw that I tightened by hand so it won't go all the way to iphone hole part. than pulled it.
the sim tray came out as easy as it seems.
I hope that would help someone as desperate as I was before I got it out.
good luck.
Edited by
0
Score
Avatar
Gadget Docs
Answered
PermalinkHistory
Worst case take a really thin paper clip and a pair of pliers and make a little hook that will still thread through the hole but you can angle it to catch on the back side and try to pull the sim tray out manually. I do know my first iPhone 4 the sim tray was just rough to get out period, had to push pretty hard with a firm paper clip to get it to pop out
0
Score
Avatar
Phil
Answered
PermalinkHistory
This is new to me!
I have the Iphone 3, 3S, 4 and now the 4S. First time in using iphones my sim card tray on the 4S is stuck. I can pop the tray out with a pin all right, but it only openned about 2.5 mm and nothing I can do will pull the tray out.
I cut a piece of think plastic sheet and was able to insert the film all the way in on top of the sim card so it does not seem to be the sim card catching on the inside.
Anyone with experience popping the SIM card tray out??
0
Score
Avatar
eddysusanto2002
Answered
PermalinkHistory
Hi Phil, I have the same problem as you.
I just bought iPhone 4S and when i tried to eject the sim card. it can only eject 2.5mm of the tray.
Tray stuck snapshot
Edited by
0
Score
Avatar
Phil
Answered
PermalinkHistory
I took the 4s down to the Hong kong Apple store and first they refuse to service it as it was purchased from a Canadian store! Limited warranty I was told! After making some fuss in front of a few hundred people waiting in line to get their hands on the 4s (just s happend to the launch date for the 4s in HK) one of the senior tech took it in and within a couple of minutes came back out with the tray unlocked and SIM card undamaged.
I was told if one has a Micro SIM that was a cut out from the regular SIM card DO NOT even think of putting this SIM card in your new 4s or else there is a great chance that you will suffer the same fate. The new 4s has such a tight torrance that if the cut out SIM has any rough edges you will not be able to pull the tray back out! And read the limited warranty part! Apple IPhones have regional warranty only! Something I have to consider next time as I travel all over the world on business and if my SIM card got stuck and I cannot get local service to unstuck it I will have to carry many cell phones around just for all the different country SIM cards I owned!
0
Score
Avatar
eddysusanto2002
Answered
PermalinkHistory
I manage to got it out by using a small screwdriver and two cutout sheet of paper. The paper is to prevent scratch on the side of the body. The side tray where it has the tiny hole got a little bent, but I manage to straight it out again.
I didn't use cut out sim, it was original from the operator M1 Singapore.
When I got it out the sim was undamaged at all which might means it was not the sim that cause the tray to stuck. After this forceful ejection I tried to insert and eject it several times and the tray doesn't seems to stuck anymore.
0
Score
Avatar
Phil
Answered
PermalinkHistory
I ended up taking it abck to Apple HK store. At first they said becasue the phone was bought in the US and Apple has only limited warranty on their IPhones (vs their other products) I need to take it back to Canada to get it fixed. That was a lot of crap as I travel all over the world and if my SIM card tray is stuck somewhere outside of North Ameria I need to have it fixed right the way or else I cannot switch SIM cards as I go from one country to another.
Fortunitely it was the launch date of the 4S in HK and there were a lot of people in the store plus a few TV crews. Finally someone higher up figured out that it may not be a good idea if I am there jumping up and down with a defective IPhone 4S on the first day of their HK launch!
It was quickly fixed (seriously it took me 45 minutes of screaming at different folks and about 2 minute for the tech to take the tray and card out so what the &$^# with this limited warranty issue?). In any case, I tape my SIM cards down onto the tray just to make sure it does not get caught again!
As for the limited warranty issue that will go into my decision on my next phone purchase. I have already mentioned my experience to a few people who travel as much or more than I do, most have decided to hold off in upgrading their Iphones.
0
Score
Avatar
Ahmed
Answered
PermalinkHistory
@phil
Don't you know what he did to fix it ?! cause I've got the same problem it only ejects about 2.5 mm, i don't know what to do ! :'(
PLEASE Reply! Thank you
0
Score
Avatar
fumihikotominaga
Answered
PermalinkHistory
I have an iPhone 4 (AT&T) with the exact same issue for 3 months i.e. a Gevey Tray stuck inside my phone and I couldn't remove it.
I tried everything I can possibly try including unassembling the whole iPhone with no luck. I've already given up but I tried with a screw as Ron suggested above and it came out as easy as it seems! I unscrewed a small screw from my TV remote and it worked perfectly.
Good luck to those who's still having an issue with it!
Edited by
0
Score
Avatar
jelestu
Answered
PermalinkHistory
My problem is that the sim card tray will slide into the phone but it won't lay flush to the phone and it sticks out just a little bit...not much at all but enough to annoy me. I haven't tried putting a sims card in yet because I am scared that it might get stuck or not work because it's not laying flush to the side of the phone.
Anybody having this problem??? HELP!
With the tray out I look inside and there is this little metal handle. I guess it helps guide the sim tray inside the phone? It looked a little bent so I just took one of my metal spudgers with the thick pointed end and gently pushed the little metal handle down some to where it looked like it was straightened out somewhat. Then I gently slid the metal sim tray inside of the phone and WAALA it worked and the sim tray is now flush against the phone and fully in place. When I bought a sim card later that day, the tray came out easily and slid right back into place. Everything works great and it is flush against the phone! Thank you for all of your help :)
jelestu,
0
Score
Avatar
Ahmed
Answered
PermalinkHistory
@jelestu
when the sim tray is in , but not laying flat, just get the needle that you use to pop the tray out and put it in the hole and press , then with your hands try to push the sim tray in,try it a couple of times.
It worked with me, good luck
0
Score
Avatar
niladri das
Answered
PermalinkHistory
My Tray was tuck too so I elf the tray (the part of t I coil pull out) and I pulled hard n it came out. But now m not sure if t has damaged some interiors
0
Score
Avatar
Robert Rodriguez
Answered
PermalinkHistory
i cut a small right triangle piece of paper and dipped the pointy
tip in wd-40
then i slid in the saturated paper and let a VERY SMALL amount
pull itself into cracks between the sim card cradle and the
phone frame on both sides as it was partially popped out
problem solved
popped out like there never was a problem
Add Your Answer
