0
Score
greggt98
Asked
SIM Tray Is Stuck Inside
Hi My iPhones SIM Tray has got stuck inside, I Insert the removal tool and there isn't anything to press down on it just goes down to the Screen and damages it, and the WIFI Doesn't work anymore, I Have just order'd a take apart kit, for the wifi is there anything to do to fix it but without more parts? Thanks Gregg
mayer, Richdave, and oldturkey03
2
Score
pollytinto
34k
Answered
Accepted Answer
to remove the sim tray without the little "flipper" inside the phone is quite easy. Use the sim tray removal tool, insert in hole and lever towards the simtray and then pull.Don't angle towards the screen (you are just going sideways to remove the sim not forwards) you can also try to make something like a little hook or L shape on the end of a paper clip and use this to lift out the sim tray. If you can put up with this then I would..how often do you want to take a sim out?
