0
Score
Dirk
11
Asked
Wifi reception poor after screen replacement
I replaced the front glass assembly on my iPhone 4. After putting it back together, everything works great but the wifi. I do get wifi but only if I'm a few feet from the router.
I have tried other screens and even put another motherboard in the phone but no better. I tried replacing the wifi antenna cable but no luck there either. I also tried different backs with no luck.
The phone was damaged (I bought it that way) slightly at the top where the headphone jack is. I used a pair of pliers to straighten the frame before putting on the screen. There are no cracks in the metal frame.
I'm at the point where I'd use a 3GS instead of this cause I can't get usable wifi anywhere.
Score
pollytinto
39k
Answered
Accepted Answer
take a look at this solution and see if it helps.. http://www.ifixit.com/Answers/View/38247...
Score
Scott Head
13.7k
Answered
It sounds like you have replaced pretty much every component that could be causing the issue. Have you verified that your router is working correctly?
Otherwise, sometimes the oils on your hands can interfere with the wireless signals. Make sure all the components you handled are cleaned off. I little bit (emphasis on "little") of screen cleaner or even Windex will do.
0
Score
Dirk
11
Answered
I had an iphone 4 in for repair last week and compared parts on it to the parts on mine. Specifically looked at the EMI shield and mine was missing what turned out to be a crucial piece. I actually found it and replaced it and now my wifi is back. I did order another complete EMI shield in case that happens again - cost only $12.
0
Score
Answered
0
Score
pimp1310
Answered
0
Score
Answered
I ordered mine from Parts4repair.co
0
Score
Bernie
Answered
i hope its helps, the signal antenna its the back glass top, when you remove the screw on the battery connector the oil on your hand affect it, so what you have to do (for me works) its clean the little metal that makes antenna together with the back top and the top, try it, it improved signal on my iPhone 4
0
Score
Bbradner
Answered
0
Score
Answered
I have the exact same problem. Replaced front screen and Wifi is very poor. In order to get full wifi signal I have to be like 5 feet from the router.
Andre Aguiar,
