Score
Glenn Miller
23
Asked
Battery Discharges While MacBook is Off, Charging Indicator Stays On
Macbook 13" late 2008 unibody
(Update: Rewrote to put more relevant info first, included additional things I tried.)
Late 2008 Macbook Pro unibody (2.4GHz). If I totally power the laptop down (not sleep, total shutdown) and leave it sitting for about a week with the battery in it, the battery drains down to about 10%. If I take the battery out for a week, the battery is at a full charge when I put it back in the laptop.
Battery does re-charge, but when I unplug the MagSafe adapter, the battery charging indicator never switches to "on battery". It continues to show as being connected to the adapter but "Not Charging" (instead of showing as running on battery).
Laptop runs fine on the battery with a reasonable life (a few hours), it just seems to never show that it's on the battery. When this behavior first started I noticed that the light on the MagSafe adapter wouldn't light for a few minutes; unplugging/repl
This may not be related, but when I powered up the other day the Macbook asked me for my password, though it's not configured for that. I gave it the correct PW but it just kept asking me for it. I finally powered it down and back up and it started up without asking me for my PW (normal behavior).
CoconutBattery shows about 86% health, but the system profiler seems to sometimes have problems fetching the battery info (sometimes shows 0/NULL values for most of the info, sometimes seems okay). I've verified that the pins in the adapter move in and out, and I've drained/recharg
3
Score
mayer
121.8k
Answered
Accepted Answer
Very perplexing problems. Please have your hard drive backed up before beginning. Time Machine to an external hard drive would be fine. My first guess is a corrupted system folder, possibly some bad blocks but not enough to cause complete start up failure. Start up from your original system installation disk and hold down the "D" key. This will run diagnostic and may give us a clue. If this fails, I would reformat the hard drive and use the "write zeros" option to map out any bad blocks. I would then install a fresh system and see if the problem persists. If the problem is gone, run Disk Utilities of the Time machine backup till it runs clear, then use Migration Assistant to load your old data.
Thank you! I'll try that, though it will be at least tomorrow until I can report back (it's my personal computer and I don't have access to it now). I had also thought about re-install...been writing and installing software for over 30 years now, so that won't be the first time I've used it to fix a problem. FWIW, the disk in the Macbook is SSD (stock from Apple). I'll still format the drive with "write zeros" but would think bad (physical) blocks are less likely than with an HDD. Luckily I've got multiple external backups (including external TM) and have prepped myself for this step already. Will report back in sometime this weekend.
Please give the last three letters of your serial number so I can make certain as to which machine you have.
Some research showed me this: Due to the need to keep cost low and yields high, NAND flash devices are shipped from the NAND manufacturer's fab with up to 2% randomly scattered Bad Blocks. In addition to the initial Bad Blocks, new Bad Blocks are created during operation when the amount of bit flips in page exceed the number that can be corrected by the ECC engine. The block where that page is located will become invalid and no longer usable (Bad Block).
Interesting points. Hopefully that increases the probability that it's a bad block. I'll see if I can get the serial # posted in the next hour or so, will try to do a clean re-install tomorrow or Saturday. Thanks for the additional info...this site is great, esp. because of folks like you.
Serial number looks like it ends in either 1B5 or 1B6 (though it could b 185 or 186). Printing is pretty rough inside that battery case, even under a magnifying glass. Re: install disk: Just to confirm, I'll use the original installation disk that came with the Macbook, not the Snow Leopard upgrade disk, and then apply the Snow Leopard update *after* we resolve the problem.
0
Score
nick
12.3k
Answered
This is normal
Uses minimal power shut down but it isn't much tough
If it's a lot,the battery is worn out
It's not in sleep mode, it's totally shut down. Would CoconutBattery report 86% battery health if it were worn out? That's not intended to be a smarmy question, BTW.
Saw edited response, but I think it's still missing a couple of key points from my original post. First, CoconutBattery reports it as 86% healthy...thoug
0
Score
Answered
Hi Glenn,
Did you ever solve this problem? i have exactly the same mac with exactly the same problem. If I leave the battery in the mac and completely shut down the mac by the next day the battery will be flat. If I leave the battery out of the macbook i can put it in a week later and it functions perfectly. Once the battery has run flat the macbook no longer charges it. The only way to resurrect the battery is to reset the SMC at which point it works as expected until next time its left in my mac.
Are you the original owner? Has this ever been exposed to liquid?
ABCellars,
I am the original owner, and it's never been exposed to liquid of any kind. 100% certain of that. Thanks.
Glenn Miller,
+ very clear question
mayer,
