0
Score
Avatar
Lou
Asked
Why is the backlight on my iPhone not working?
History
I dont remember doing anything to my iphone to cause the backlight to go out. I havent got it wet, or dropped it. I have and iPhone 3gs 16 GB white case. i was playing a game on it, in my house, and then 5 minutes later, i went to check my email, and the backlight didnt work.
I can still see the screen if i shine a light across it. and everythig alse still works. I have tried setting the brightness haighter and lower, but that doesnt do anything.
what do I need to do to fix the backlight? If i need to buy materials what do i need? Ive never taken apart an electronic device before but im ready to give it a try if I can fix my phone.
Your help would be greatly appreciated.
Post Answer
2
Score
Avatar
oldturkey03
87.9k
Answered
PermalinkHistory
Lou, disassemble your iphone with the instructions on here Take your time and familiarize yourself with the instructions first. Read the comments and the notes and make sure you understand the instructions. Once you have it disassembled take a look at the attached image and identify the coil and the area around the coil and clean it very good with isopropyl alcohol and a soft brush. Check for corrosion and debris etc. It may resolve the issue or you may have to replace/fix the coil. Let us know how it is going so we can continue to assist you if needed. Just take your time and find an area with good light and you will be fine. We are all here to help you.
Add Your Answer
