0
Score
Avatar
lac
Asked
Earpiece speaker/bluetooth/mobile netowork issues!
History
Earpiece speaker doesn't work in any application regardless of volume, bluetooth is not detected/doesn't find anything in search even though it is enabled and connection to any network gsm mobile network 2G or 3G is varying/dropouts out/usually has one bar/no service.
Loudspeaker works beautifully/generally sends texts ok/internet and calls generally drop out/stop.
I've already reloaded the OS/downgrade/upgraded/changed sims
Unsure as to what caused the problems..
Thanks in advance!
Edited by: David Hodson ( )
just wondering if this is still a problem? has the phone been dropped or damage especially to the rim? if you look at the teardown you can see the antennas are in this area..
pollytintop,
Post Answer
0
Score
Avatar
lac
Answered
PermalinkHistory
yes it is, id assume it has many a time...do you suggest replacing the midplate as a solution? thanks again!
Add Your Answer
