Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Dropped, screen fine but will not turn on
Dropped iPhone on kitchen floor, screen survived, everything looks fine but it will not power up. I have tried the USB but iTunes does not recognise it.I have opened it but cannot see loose connections but did not look under silver panels.
Does anybody know what is the likely problem and whether it is worth fixing.
Score 1
1 Comment
where's the damage on the outside?
by
Add a comment
Chosen Solution
Hi,
Is your iPhone of the 3 series? Is so, carefully open your iPhone with suction cup, again very carefully or you will tear the 1,2,3 ribbon cables or worse. Make sure Cable #4 is seated perfectly to the Logic Board. Really make sure, check it. Do not hit the power button accidently, because iPhone 3gs should not be ON when you put it back together. Then close the iPhone back up again very carefully.
Good luck,
Brad
Add a comment
Hi dear!
I am mobile phone engineer and working since 7 years......
By the way.you have to check your battery first.........if no luck then
first of all..the thing is that...you have to change your on/off flex calbe first....if no luck.then you have to change your lcd.and also need to check your lcd connecter as well...
if again no luck.
it need to check step by step becasue in case of dead mobile we wont get any idea that whats wrong with the fone......
if you know about the ic and main chips on the mother board then you have to check first of all the little transistors and capacitors on main board using with the Multimeter .
any further information....
you can call me on this no.......
Gud bye and have a nice time .....dear
1 Comment:
thanks for your helpful advice. You may put contact information on your profile page but it is regarded as spam if you have it as part of your answer.
by
Add a comment
Try to reset it by holding the sleep/wake button and home button until an apple logo appears. Connect to a power supply in case the battery has drained during the troubleshoot process.
Add a comment
Add your answer
dave will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,484
