Score
Avatar
msilver336
13
Asked
Battery "Not charging"; Replaced PRAM Battery, no luck
History
PowerBook G4 15" 1.67GHZ
Had an older battery (replaced as part of recall) that was not charging. I replaced the battery and AC adapter, which was also flakey. Still not charging. After resetting PRAM and NVRAM, decided to replace the PRAM battery. Still no joy. Is my next step to replace the DC IN?
Edited by: mayer ( )
Post Answer
4
Score
Avatar
mayer
148.5k
Answered
PermalinkHistory
What color lights are you getting on you AC charger jack? Please download and run Coconut Battery so we can get a better idea of what's going on. There's a new version but I don't know if it runs on the older machines: http://www.coconut-flavour.com/coconutba...
We are probably looking at either the DC-IN board or the battery connector. Visually examine them for corrosion. Please let us know your results. Thanks
current battery charge 4320 mAh max batt charge 65308 current batt capacity 65308 original batt cap 4607 battery-loadcycles 0 charger connected yes batt is charging no The original AC charger is flakey and I replaced it with a 3rd party 65w one with no lights. When I use the original, it's yellow for a few min and then turns green. Similarly, if I start coconut when the machine is first powered on, it does say "charging yes", but that eventually flips to no (same with the battery icon, which shows 10 hours to charge initially, before changing to not charging). The connector looks very clean, even under a bright LED light.
msilver336,
Since you new battery has never been recharged I would first check the logicboard connection to the battery connector, that failing replace it: http://www.ifixit.com/Guide/Repair/Insta... Here's the part: http://www.ifixit.com/PowerBook-Parts/G4...
mayer,
Installed the new battery connector and still no luck. I also found the original battery and it also shows no cycles in coconut, and it's a battery I used for years. Further, the machine would not power up with the AC adapter plugged in and either no battery or the totally dead old battery. Does that tell you anything? Thanks. Mike
msilver336,
I think I'm giving up.
msilver336,
0
Score
Avatar
marakatabee
Answered
PermalinkHistory
This is a year old question. So, I may be too late to answer it, but I had the same problem. Coconut showed battery life good, charger connected, charging no. I removed the battery with the laptop bottom facing down and a little screw fell out. I reinstalled that battery screw and tightened up the other screw too. In my case, that did it. Now, the battery is charging again. Good luck.
Add Your Answer
