0
Score
Asked
Core Duo 2.0 Not Charging New Battery and Adapter.
My MacBook pro will not charge. I bought a new adapter and battery. Once the battery ran down, the computer died. The adapter shows a steady bright green light. When it is plugged in, I can hear a clicking sound if I put the laptop to my ear. I though it was the io board but the adapter is lit up. Scared it is a logic board issue.
Score
mayer
121.8k
Answered
Sounds like you may have bad MagSafe port. Please give the last three letters of your serial number so your Book can be exactly identifies and we'll get you to the correct part and guide for replacement.
UPDATE Here's how to replace the I/O board Installing MacBook Pro 15" Core Duo Model A1150 Left I/O Board
Here's the board: MacBook Pro 15" (Model A1150) Left I/O Board
Includes MagSafe power, USB, and audio ports — 12 available at 99.95 each.
UPDATE Has it gotten wet? Try reseating your battery connector to logic board cable. http://www.ifixit.com/Guide/Repair/Insta... Also remove the battery and using a multimeter, check the output of the battery connector. If there is no output, replace the connector. http://www.ifixit.com/MacBook-Parts/MacB...
0
Score
blucy
Answered
I installed the new board and it now will boot. However, the battery will not charge. I am getting a bright green light on the adapter. The new battery only shows 29 cycles and -1 charge on coconut battery app.
Thanks. They are: VWW
Brian Lucy,
Apple MacBook Pro "Core Duo" 2.0 15" Specs Identifiers: MacBook Pro - MA464LL/A* - MacBookPro1,1 - A1150 - N/A
mayer,
