Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
iPhone not working after battery change!
recently the iphone 3g that i have was working fine. i needed the battery changed in it and had a friend replace it for me. well now that the battery(is brand new and works)was changed the iphone know longer works. i have tried looking through to make sure everything was connected correctly and it seems to be, the only conclusion i could come up with is that there are a few screws missing. The first two that you undo to phone,and one that holds the logic board down. anyone have suggestions for it plz and thank you!!! im just a chick who doesnt know about small stuff like this!!!
Score -1
Add a comment
1 Answer
Most Helpful Answer
Have you tried turning vibrate on/off? it'll let you know whether the battery is dead/not connected (no vibrate) or your display isn't connected (connector 1)
I'd put the old battery back in and see what happens. Or, check connector 4 (the dock) and make sure the screw near/under the "don't remove" sticker are in tight enough to give good contact with the battery.
Score 2
Add a comment
Add your answer
ashlee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,420
