Score
Avatar
danieltian
13
Asked
How can I improve the grip on the 54-bit kit screwdriver?
History
How can I improve the grip on the screwdriver in the 54-bit kit? The shaft of the screwdriver is completely smooth except for 3 rubber rings that rotate in place when you turn them and some dimples that don't seem to do much. I'm having trouble removing screws that are screwed on really tight; I end up using a different screwdriver almost every time because I can't seem to get enough grip on the kit screwdriver.
Post Answer
3
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
I have the kit you have and also the smaller kit. The smaller one has a larger diameter handle and it feels like I can get about double the torque on it. It's an inexpensive set plus I don't have to change bits as often when using both drivers. Here it is: 26 Bit Driver Kit
Product Image
26 Bit Driver Kit
Screwdriver kit includes almost all of the Phillips and Torx drivers we carry. — 50+ available at 14.95 each.
Thanks, I purchased that kit hoping that the screwdriver in that one is better. Plus, I needed bigger bits for bigger things like desktop computers, so it works out.
danieltian,
Glad I could help.
mayer,
Add Your Answer
