Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Questions View all
monitor has yellow square on screen
Yellow square is 2 inches from left and about 2 inches wide. External monitor connection is OK. Can still see screen contents but discolored.
Score 2
Add a comment
1 Answer
Chosen Solution
You have a TAB fault in your LCD. The LCD is not repairable, it needs replaced. You should be able to find a LCD on eBay for your model. The replacement instructions are in the service/hardware manual. You can get the service/hardware manual from HP the support web site. You didn't give your model number or I would have provided a link to it.
Score 4
3 Comments:
+ what's a "tab" fault?
by
Tape automated bonding (TAB) faults - A TAB fault is caused by a connection failure from the TAB that connects the transparent electrode layers to the video driver board of an LCD. TAB is one of several methods employed in the LCD display manufacturing process to electrically connect hundreds of signal paths going to the rows and columns of electrodes in layer 6 (the transparent electrode layer) in the LCD display to the video ICs on the driver board that drive these electrodes. This definition came from here: http://en.wikipedia.org/wiki/Defective_p...
Some of their symptoms can be seen here, http://www.lcdparts.net/howto/symptom.as... , as well as other LCD problems.
by
Like what I'm seeing here....will u marry me? ;op
by
Add a comment
Add your answer
charlie kotsaftis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,289
