4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 Questions View all
Wifi doesn't seem to be working. Is this fixable?
Every time I try to connect to wifi it tells me the signal is too weak. I've tried plugging it in to the PS3/PS4 and the router and no luck. Any ideas? Is there a way to replace the wireless card/broadband adapter?
Score 1
Add a comment
Chosen Solution
Hi!
While there is no user replaceable WiFi-Card, you could try reseating the antenna connector. Follow this guide until step 11 and unplug the cable that's marked with purple in the guide. If that does not work either get closer to the router or replace the main board. Note that even if you plug the PSP into a PS3/ PS4/ router via USB the internet connection won't be shared.
Score 2
4 Comments:
Note that the PSP 2000 is an 802.11b only card. You will have to double check that the Wi-Fi on your router is set to allow ancient 802.11b.
by
@avanteguarde Yeah, right, I forgot about that. Most routers do support that old standard tough
by
@alexniculescu I agree it is supported, but it is disabled. The reason being is WPA2, especially WPA2-AES does not work with 802.11b.
by
I was also wondering about the 802.11b. That would probably make a difference as well. Thanks for the help guys.
by
Add a comment
It will always say signal too weak. There is nothing wrong with the WiFi card, but the communication protocol is outdated and no longer supported, hence the said error.
Just buy an old router that is still compatible and bridge to your network.
Score 1
Add a comment
https://youtu.be/a4qjcvZ6xFE
Add a comment
Add your answer
jbrady2 will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 12
Past 30 Days: 17
All Time: 1,915
