The fourth-generation Surface Pro tablet, released October 26th, 2015.
210 Questions View all
Screen Replaced but touch screen doesn't work
So I just replaced the screen on a surface pro 4, however the touch screen doesn't work when i use my fingers. It works fantastic with the pen and with the keyboard, but not when I use my fingers. The cables are seated properly so I don't know what the issue could be.
Score 1
Add a comment
1 Answer
Chosen Solution
Did you double check the digitizer board behind the screen to see if the ribbon cables are fully inserted and clipped in?
Score 2
8 Comments:
yea they're all seated and everything. the digitizer works, the screen cuts on and everything. i just can't use my fingers.
by
The touch screen is defective on the screen, which is pretty unfortunate.
I'm guessing you already checked the touch screen cable that plugs into the surface logic board and the mini board on the screen.
by
aww man! I did check the cables on the ntrig and the other cables as well. they're all seated properly. im going to do another check and then have someone else look at it to double check. i haven't sealed it yet so that's the good news.
by
Just checked it, the emi shield was messing with the touchscreen connector. thanks so much for all of your help!!
by
I have a similar problem, I replaced my screen on SP4, everything seems to be connected properly, I checked various times but half of my screen does not respond to touch, any ideas?
by
Show 3 more comments
Add a comment
Add your answer
LMJ will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,512
