0
Score
roaddog10
11
Asked
What kind of logic board?
Hi here is the serial number M9848LL/A Model # A1134 I hope this helps?!!
4
Score
mayer
121.8k
Answered
This was the last iBook made so you already have the top end machine. Here's the logic board: iBook G4 14" 1.42 GHz Logic Board
This answer was originally to another question.
1.42 GHz Motherboard / 512 MB RAM / Ports: 100BaseT Ethernet, Firewire, 2 USB 2.0, VGA Video Out, Audio Out — Currently out of stock.
2
Score
mayer
121.8k
Answered
If your machine will start up, go under the Apple to "about this Mac" more info Hardware. This will tell you about your logic board. If you give us the last three letters of your serial number I can tell you what the logic board should be. Also look in the battery compartment for your processor type and serial number.
Score
lemerise
16.2k
Answered
No you cannot replace the 1.33 GHz logic board with a 1.42 GHz one. Hard drive set up, airport card socket, inverter socket, reed switch board location, track pad are different so no you can't swap.
0
Score
ricomac
Answered
The late 2004 1.33ghz logic board is not compatible with the mid 2005 1.42ghz iBook and vis-versa. The logic boards of those iBook doesn't have same layout. The airport card is an "user" add in option on the late 2004 but not on the mid 2005 which is a standard feature with the bluetooth.
By the way, I have on my workbench a mid 2005 iBook opened and the airport card seem to cause kernel panic. The KP is resolved when the airport card is unconnected to the logicboard. I'll try the plastic spacer trick which consist to put an little piece of plastic in between the airpot card and the retaining bracket which retaining it close to the logic board.
Please add this as a comment to your original question. Besides that's a part number but it will work.
mayer,
