0
Score
Avatar
Igor Santos
Asked
Has anyone installed a SSD in a A1176 Mac Mini1,1?
History
Hi,
I haven't been able to find a successful installation description of a SSD in a A1176 Mac Mini1,1. Can anybody confirm it is possible? Can you recommend any SSD model?
Thanks,
Igor.
Edited by
Post Answer
4
Score
Avatar
rdklinc
15.3k
Answered
Accepted Answer
PermalinkHistory
An SSD drive is physically exactly the same as a regular SATA drive, with the same SATA connector. So as far as installation, there is nothing specific to SSDs, and you can therefore use the guide for installing a regular SATA into an A1176:
Installing Mac mini Model A1176 Hard Drive
Edited by
0
Score
Avatar
alfredo
13
Answered
PermalinkHistory
I just installed a ssd in my Mac mini with a 1.86GHz CPU.
It was very easy, the hardest part was taking off the top.
Once the ssd installed I just booted off my Snow Leopard DVD and done.
What problems are you having?
If you put your orignial HD into a USB enclosure you can hook it up and boot off of it first.
You will see the ssd as a attached drive in Disk utility program.
Format the ssd and install new OS.
0
Score
Avatar
Olivier Boigey
Answered
PermalinkHistory
Hi, is it possible to remove the optical drive and replace it with an SSD ?
0
Score
Avatar
alfredo
13
Answered
PermalinkHistory
It's not a god idea to put the ssd where the optical drive is. That bus is very slow and will cripple your SSD speed. I believe the optical drive is on a PATA bus.
Add Your Answer
