0
Score
jcarter
317
Asked
Startup Disk HDD not recognized... fix/alternatives?
Hi all -
I have a macbook pro 2GHz Core Duo that I recently purchased... knowing it was having trouble booting from the internal hdd. After removing the logic board, cleaning it, reseating, etc... I got it to boot up to the hard disk twice and then it went back to only booting from the optical bay or an external hdd.
I'm assuming this is a hard drive controller issue, correct? Any suggestions? I know I can remove the optical bay and install the after market hard drive bay, but if I want to keep my dvd drive, are there any fixes? I did note that all the pre-unibody macbook pro logic boards have an unused port site to the left of the optical bay but before the memory opening. Is that a potential site I could link some "X" cable to?
Thanks
PS - I tested using both another HDD and another HDD flex cable
0
Score
mayer
121.8k
Answered
Accepted Answer
Yes you can use the optical bay adapter: 9.5 mm Optical Bay SATA Hard Drive Enclosure
You might want to consider replacing the hard drive cable: MacBook Pro 15" (Model A1150) Hard Drive Cable
Do not use that port, it is for Apple factory testing.
9.5 mm Internal ATA Optical Bay for SATA Hard Drives — 37 available at 59.95 each.
Connects hard drive, sleep light, IR sensor, and Bluetooth board to logic board. — 6 available at 39.95 each.
