0
Score
Avatar
humayon khan
Asked
I press button with my face while making ph.calls
History
When I call friends and family and hold the phone close to my face, i inadvertently keep on pressing mute button or speaker button with my ear or face which is very annoying. My understanding is that there is a proximity sensor in the iphone and I have seen my friends phone and their screen becomes black once the phone gets close to their face. Mine does not
Humayon B khan
Edited by: mayer ( )
Post Answer
2
Score
Avatar
hectordtruong
6.7k
Answered
Accepted Answer
PermalinkHistory
Definitely check the #3 ribbon. If it is damaged, you will have to swap it out without damaging the connector. Here is a guide
iPhone 3GS Proximity Sensor Ribbon Replacement
Well done getting a guide done!
pollytintop,
Thanks Polly!
hectordtruong,
I have changed the cable with a new one but the only problem is that i can not get the ribbin all the way into the slot. The pboblem remains. what should I used to guide it all the way in to the slot before putting the bar down, I am not sure even if that will fix the problem
humayon khan,
WHat I do is hold the phone in my left hand upside down and the screen in my right hand upside down. I use my index finger and thumb to hold the screen. The middle finger is in charge of lining up the ribbon to the connector, once it is lined up, i advance it forward and clamp down. Ive done this probably thousands of time so I have the technique down. Just take it slow. A new ribbon is stiff and is easier.
hectordtruong,
That's the trick, I replaced a broken LCD and was hitting the mute and speaker with my face while on phone calls. I took the lcd back off and reseeded my #3 ribbon and now it woks perfect.
Vitaliy Levitskiy,
Score
Avatar
repairthat
143
Answered
PermalinkHistory
You might want to check the ribbon cable connection 3. This connects the proximity sensor. The connector is called a ZIF connector, and has a special way of opening it. you should look for info on how to open it (basically flipping up a lever, and gently pulling or pushing the ribbon cable out.) Be careful, the internet is full of stories of people breaking the connector. it's a pain to replace.
Make sure that the connection is firmly/deeply in before flipping the lever back down.
hope this helps.
Add Your Answer
Today: 0
This Week: 4
This Month: 15
All Time: 1,967
