2
Score
nancy
35
Asked
Nano keeps turning itself off
I have the 6th generation Nano and it keeps turning itself off after playing music for about 2 minutes. Battery shows charged and good to go. I turn it back on and resume the song that was playing and it goes for about 2 minutes and turns off again. I have looked on Apple's website and others for answer to this problem but have not seen any questions pertaining to this problem. Any ideas?
7
Score
Michele
99
Answered
Accepted Answer
Yes when pusing in the head phones they have to click, no shiny part should be showing.
Boy, am I glad that I found this forum. My I-Pod Nano would turn off after a minute. All I had to do is push the headphone jack all the way. Thanks so much.
thanks for this,I had same problem would turn itself off after about 2 mins while listening with headphones and now that I have read this and pushed plug right in it works!! You would think the apple service person I sent it to would have thought of this when I said the headphones were playing up!!! Having never had an ipod I didn't realise you had to click it right it, sounds logical now that I know. Cheers
Thanks for this. I just got my nano and I thought maybe one of my kids got a hold of it and ruined it or something! I looked everywhere for troubleshooting support on this issue and found nothing on Apple's website!! How ridiculous is that??!! I couldn't get the radio to work, either. It said I needed to plug the headphones in all the way, but I thought I had. I was literally planning on taking this thing back to the store tomorrow morning until finding this discussion board. Thanks!!
Thanks - I had the same problem. It did not turn off though if connected to the computer via USB. Push the plug right in which is not obvious and it now works without shutting down.
RonC,
3
Score
Margie
37
Answered
Make sure your headphones are pushed all the way in.
I swear I did this on the first nano I had but it did not work. But on my replacement nano that seemed to have done the trick. Go figure.
i was experiencing the same problem. i pushed the headphones in all the way, felt a click, and now it works just fine! well, it works so far... :-) christie
just make sure your headphones is plugged all the way!mine was doing the same thing and i just pushed them all the way,so now there is no more issues
2
Score
Devon
25
Answered
if you look closely at your head phone jack you will notice the he phones aren't all the way inn to you half to push them all the way you will hear a pop and the sound causality will be better
Thanks for that, trying to be to gentle but forced the jack in all the way and its done the trick, Marvelous many many thanks.
Frog,
My brand new 6th Gen Nano also does the same. In addition the earphone jack is tempremental and loose. There is no lock button and the off switch is in such a stupid place. Everytime you need to adjust the earphone jack you end up turning it off. Taking mine back for a refund as it is a really bad piece of kit. Should have learned my lesson with Apple after buying the original first gen ipod with a battery that lasts for about 2 hours. In my experience their products suck.
As Devon suggested, pushed the earphone jack in till it clicked and that seems to have done the trick with the supplied earphones. Thanks dude! However I still stand by my comment on the off switch and lock button. Unless someone can advise otherwise! Maybe they should have designed the off switch to be a dual lock switch? Now just need to find out if I can get on with its functionality. PS: Sound quality is top notch.
0
Score
Answered
I had same problem from new nano at Easter, no amount of pushing in the headphones properly fixed it. Apple replaced it no problem and the new one was fine until yesterday. (August)
We have tried several different sets of headphones & a speaker with the same result; as soon as the backlight goes out, the sound stops. I left it all day without unplugging the headphones then when my electrical engineer son turned up tonight, it played ok.
I'm sure that this is some intermittent fault that Apple know about - hence the ease with which Apple will replace the units.
0
Score
Greg
Answered
I just had this problem from a 6G that I received at christmas. The headphones were indeed ALL the way in, tried that several times no luck. Tried getting an update, but am on O/S 1.2 (most current version).
Was about to go to the apple store when I remembered that I had another pair of earbuds from an old iPod, tried the old earbuds...probl
For those still having issues, make sure to try another set of headphones before heading out to the apple store :)
0
Score
Nikki
Answered
I took the ipod to Apple and they are replacing it. They could not find the reason it was turning itself off. They figure it is just a flaw in the internal programing. Thanks for all the suggestions.
nancy,
nancy, great that you got it going, now all you have left is to accept the answer that helped you to resolve your issue. This way we know your case is closed :-)
oldturkey03,
Thanks so much for all the help everyone.
nancy,
I had the same problem - i have returned it and had it replaced - and my brand new replacement is doing the same thing.
scott shilling,
I just got replacement and it did the same thing. Then I pushed the ear plugs in all the way and it WORKS! Weird how something like that would make ipod shut itself off. When I took it in to Apple you would think that would have been the first thing the guy would have looked at. Finally I have touch screen ipod that actually works. Now, I have to figure out if I like it or not.
nancy,
Hey Nancy. Thanks for the hint. I had the same problem (switch off after 2 minutes) but with a nano 4g and earplugs from seenheiser (which might not have exactly the same effect on the socket as the original earplugs). Although your solution did not work on the first tries, it worked now after a few repetitions and complete un- and replugging. I'm still wondering about the causality...
Andi,
Wow I got a lot of response on this remendy in the last couple of days. Apple must have sold a lot of these Ipods for Christmas. It just amazes me that Apple would have such a simple problem to a popular item that they do not fix or at least let consumer know the headphone plug in is very sensitive. Glad this thread has been helpful to you guys. Happy New Year!
nancy,
Show 2 more comments
