0
Score
George
Asked
Why were the volts of the second battery decreased?
One day, I realized that my iPod Touch wouldn't turn on, so I opened it and I diagnosed that the volts of the battery weren't 3.7 (as they had to be), but 2.1! So I replaced that battery with a new one, and my iPod worked successfully. But after three days, it stoped working again! Then I checked again the battery and the volts were 3.04! Could anyone help me, please?
Edited by: oldturkey03, machead3, and rj713 ( )
Score
Michael C
329
Answered
Accepted Answer
The voltage should increase when you charge it (as far as I know) so if it's not charging then it could be something else. Like a problem with the dock conector.
Thank you for your answer BUT I am not sure that the dock connector has any problem, because: 1st) Before the second battery broke down, it was getting charged and 2nd)I had exactly the same problem with my first battery but, as I wrote before, my second battery was getting charged.
So your saying that after the first discharge it will charge up again, but won't hold it's charge after that?
I have just been reading that some People have just restored their iPod In iTunes and this has fixed it. Are you still able to turn it on? Or is it completely no responsive?
To oldturkey03: The second battery got charged 3 times and then it broke down. To Michael C: As my second battery had broken down, I opened my iPod Touch and soldered the battery again, and then I connected only the Lcd Display and it turned on again, BUT when I connected all the other stuff (Metal Backplate and Front Panel) it didn't turn on. Then, I tried again only with the Lcd Display, but it didnt turn on...
Score
Answered
3.7v is the nominal voltage for a lithium polymer battery cell. If you look at a graph of the amount of charge left in the battery, and what voltage the battery is at, the majority of that graph would be at 3.7v. These cells, however, when fully charged, reach 4.2v, and when your iPod shuts off, it should be between 2v and 2.5v. This is because the battery can be permanently damaged if discharged below 2v. In this case, your battery is functioning perfectly, so your issue is with something else in your ipod
