0
Score
Avatar
Lisa
Asked
Battery proper Current spec's
History
What is the proper part number for the 2nd Gen battery? What is the mAh ?
doing my research and found some discrepancy's
- found this on Wikipedia - 2nd generation:
2.92 Wh, 789 mAh
as I have seen them sold with 3.7 Volt Li-Polymer iPod Battery (2200 mAh) and also 880 mAh.
Thank you
Post Answer
2
Score
Avatar
oldturkey03
59.5k
Answered
PermalinkHistory
The capacity of a rechargeable battery is measured in mAh.An ampere-hour or amp-hour (symbol Ah , A·h, A h) is a unit of electric charge, with sub-units milliampere-hour (mAh) and milliampere second (mAs) from wikipedia The specs for the iPod touc 2nd gen is
Lithium Polymer
3.7 volts
800 mAh
and is available at ifixit
Good Luck to you
Product Image
iPod Touch Gen 2 Replacement Battery
Installation requires soldering — 50+ available at 14.95 each.
0
Score
Avatar
natemama
Answered
PermalinkHistory
are u able to put a 2200 mAh battery into an ipod touch 2nd gen, and with what result?
Add Your Answer
