Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
monitor goes black when using it, comes back on when move cover
Monitor goes black some time when in use but comes back when I move cover up and down
Score -1
Add a comment
Chosen Solution
Replace the inverter cable.
Score 2
5 Comments:
Why the inverter cable instead of the DDC? How do you know which one it is?
by
If the problem was the LVDS cable, the screen would loose the video but not the lightning so it would not be black. When the screen lightning cut while moving the lid up and down it's a inverter cable issue.
by
+ So we would get a faint desktop image like with a failed inverter or not?
by
yes, active video but no screen lightning.
by
Same trouble, replaced inverter cable and display but the problem still unsolved. Any suggestions?
by
Add a comment
Most Helpful Answer
Your most likely problem is a worn Display Data Cable. I would replace it. Here's the part: MacBook Display Data Cable
There is no direct guide on doing this so you need to read through a couple of other, identify your part and go from there. Here a good start: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
MacBook Core 2 Duo Display Replacement
MacBook Display Data Cable Image
Product
$19.99
MacBook Core 2 Duo Display Image
Guide
Difficulty:
Difficult
1 - 2 hours
MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181 Image
Guide
Difficulty:
Moderate
1 hour
Score 2
Add a comment
Add your answer
Betty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,115
