The Fujitsu LifeBook T902 is an old school convertible and tries to combine the benefits of tablets and notebooks. A new case, updated technology and a classical business orientation are connected with high expectations for the performance, quality and the features.
5 Questions View all
3 laptops with Windows 7 Ult reinstalled won't reconnect to network.
I recently installed a new version of Windows 7 Ult. onto three computers. two were Fujitsu, one was Dell, previously they had Windows 7 Pro. One has given me no issues, the other Fujitsu connected to the every network fine, but then wouldn't connect to the office network. After bringing it home, and connecting it to my network, it said there was a problem and the diagnostic fixed it.
The Dell reacted the same way, connected to everything fine, then when it goto the office it connected fine, but then after it was brought home, when it went back to the office, it didn't connect. At this point, the only computer that is causing problems is the Dell, it says it is connected, but the browser isn't working at the office. It works fine at any home network.
Any ideas?
1 Comment:
Check the connection settings, is it set for Auto or set to a setting that is not supported by the office network. Does the office network require a sign in?
by
Add a comment
1 Answer
you can try to restart your computer at the POST press f10 then click on restore default, then exist, then save the changes if you pc will continue having this problem then there will be a problem on your network card which is in the motherboard of your pc
Add a comment
Add your answer
gatewaynomad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 147
