Score
Philip
13
Asked
Replaced battery, worked fine for day, now won't charge
Someone put a 15 gb 3rd gen Ipod in the recycling bin at work, so I don't know for sure what the problem with it was. I bought a new battery and wall charger on eBay and replaced it myself. As soon as I closed it, it started working fine. There was about half a charge on the battery. I used it for a few hours and then put it on the wall charger overnight. When I tried to turn it on, the Apple logo came on and a picture of a battery with an exclamation point in a triangle, then it shuts down. I tried pressing the menu and play buttons together to reset it, and I opened it up again to make sure the connections hadn't come loose. Any ideas what may be wrong?
Edited by: pollytintop, mayer, rj713, machead3, and osvaldo ( ) , machead3 ( )
4
Score
oldturkey0
87.7k
Answered
Accepted Answer
Since you were capable of using it for a couple of hours, I seriously doubt that it is installed wrong. First off the 3rd gen needs firewire to charge and does not charge with USB. Your cable may fit and all but USB charging is not supported. So that should be the first part you need to do. The other possibility is that you are having dock connector issues. Clean it out and check that the pins are not bend or corroded. This model iPod is actually a lot less prone to any issues than the models after it. Yes, iTunes supports this model without any difficulties. Hope this will help you all to at least get started. Good Luck
Thank you so very much. I was trying to charge the newly installed battery with usb. I totally forgot about using firewire to charge the battery. Thanks a million.
I have the sane problem! I replace with a new battery (ebay) workshop for 4 hours, let charge in the night and now the same signal of no battery! This OLD model have sentimmental value. Plz help! Rickricardu
-1
Score
tklesse
Answered
i say its too old and i wonder if itunes still has support for that modle but %@*!, i think the batt was installed incorrectly, (check the cables) or the battery is defected and return it!
Tim Klesse
KlesseTech
Edited by: Taylor Arnicar ( )
