0
Score
Avatar
kelly
Asked
How do I change the ignition switch on this 96 cavalier
History
need to change ignition switch for 96 cavalier witl 2.2l
Edited by: Sam Lionheart ( )
Post Answer
0
Score
Avatar
oldturkey03
91.2k
Answered
PermalinkHistory
Wonder if your cavalier suffered from this http://repairpal.com/chevrolet-cavalier-... anyhow, got some basic instructions here Caution:On models with a Delco Loc 2 or Theftlock audio system be sure the lockout feature is turned off before proceeding
  • Disable the airbag system
  • Remove the tilt lever if equipped
  • Remove the upper and lower steering column covers
Ignition Switch
  • Remove the ignition switch retaining screws
  • Detach the ignition switch from the steering column housing assembly and unplug the electrical connectors
Key Lock Cylinder
  • Turn the key to the run postion
  • Depress the lock button and remove the key lock cylinder
http://wiki.answers.com/Q/How_do_you_rep...
Add Your Answer
