0
Score
Avatar
Tom
Asked
Advice on replacing a 2007 iMac Aluminum Hard Drive
History
iMac Intel 2007 model
Hi Folks
Im thinking about replacing the hard disk drive in my 20 inch 2007 aluminum Intel iMac
Over the last three years it has gotten heavy use from audio recording and audio processing and as a result has slowed down some. I was wondering if anyone could give me some advice on what a good model hard disk would be to get for the job. I'll most likely go for 1TB to 2TB.
Iv done some research and have seen guides on how to do this and have been told that i need a 3.5 inch drive to fit properly, if any one could confirm this i would be thankful.
Also could anyone suggest other components that may need maintenance or replacing (based on possible reputations for failing) as id be happy to do this all at once to prolong the life of my Imac
Thanks in advance for any help (also im not hugely familiar with this site so if this is the wrong place to ask this question or is bad user etiquette I apologize in advance as well)
Edited by
Post Answer
2
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
I've changed your machine selection to the most likely machine. Check on the bottom of your stand to insure it's correct. Here's how to do it: iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
As for the drive, with heavy recording use I would go with a high end drive meant for heavy usage such as this 600 GB Raptor: http://www.newegg.com/Product/Product.as...
Of course you can use any standard 3.5" SATA hard drive but will have greatly reduced performance. You can also go with one of the SSD drives: http://eshop.macsales.com/search/ssd
Thanks for your help Mayer, Western Digital came up a few times when i was researching drives but I dont have a great knowledge of hard disks and wasn sure what a good model would be for my needs. I appreciate the help.
Tom,
I like the Western Digital Scorpio Black drives (7200 rpm). I keep them in stock as my standard selection for replacement drives. You get what you pay for with hard drives. The general run of the mill hard drive is made as cheaply as possible to compete in the market. Sure, your race car will get around the track with a four cylinder engine, but to adequately do the job, you need a formula one racing engine built for high speed and endurance. Really look at the Raptor drives before making a decision, please.
mayer,
Here's a 300GB VelociRaptor for $170: http://www.newegg.com/Product/Product.as... The 600 GB is $275: http://www.newegg.com/Product/Product.as... I've never seen one of these fail.
mayer,
Add Your Answer
