0
Score
Asked
Power button is stuck
The power button on my Ipod Naon 6th generation is stuck. As in, my ipod won't turn on unless I plug it into the computer to make it light up. PLEASE help me!!
0
Score
Answered
4
Score
rbarrioss
49
Answered
2
Score
oldturkey0
59.5k
Answered
Emily Routh, if it works when you plug it in, but not when it is not connected, start replacing your battery. After that you have at least a starting point if you should continue to have problems.Installing iPod Nano 6th Generation Logic Board Assembly gives you an idea of how to do it. Good Luck and let us know if you need more help.
0
Score
Jeleana
Answered
My ipod button is stuck as well. People are saying that it is very common and maybey if it is common we should all get replacements free of expense
take a look at the link from rbarrioss.. it looks pretty straightforward and may fix your problem. use a guide on the right under the photo of your ipod to open it to the power button assembly.
0
Score
e2648
Answered
I'm working on one of these right now, and taking it apart was easy enough, but the solution from R. Barrios isn't always the answer.
My metal shim between the outside button and the inside one is perfectly centered, as shown in Barrios' finished product. The problem is that the button can't be pushed in far enough to make contact with the (loosely taped) internal button.
I have tried adding another metal shim, and even a thicker plastic shim, but didn't have any luck there.
This iPod isn't returnable even though it's under warranty because of a cracked screen; fair enough. However, there should be a replacement program for these defective 6th generation units.
Not that I'm surprised though, as Apple has a tendency to make design decisions like this, even admitting that they've got issues, and then not do anything about it.
Disposable society indeed!
0
Score
Vince
Answered
0
Score
Amanda
Answered
i have the same issue. I'm thinking about bothering the nearest Apple Store because I think it's still under warranty. I have a few scratches on the screen, but I don't think that they can say it's not under warranty because of that. If not I'll take it to a repair place where they also fix ipods.
0
Score
nikki
Answered
0
Score
Answered
0
Score
Ben Levy
Answered
0
Score
Sven
Answered
The Standby/Power button on my iPod nano 6G got stuck, making it impossible to turn on the iPod (except via USB). With the warranty having expired a few months ago, I gave it a try to fix it.
It was of course the small metal shim under the power button that just slipped a bit to the side. Reseating the shim did the trick. With the right tools it took about 30 minutes.
Note: There was a black tape over the button assembly, all along the inside of the top of the case. This tape is not shown in the tear-down pics and had to be peeled off to reach the power button.
I wonder why Apple opted for such a bad design. It almost appears as if this is some improvised solution.
Before I forget - many thanks to iFixit for the tear-down pictures and to R. Barrios for the detailed explanation of the actual problem!
Somehow the glue strip between the display and the case has suffered a bit when I disassembled the nano and I notice the backlight shining through at the edges of the display. Does anybody have a solution for replacing that glue strip?
0
Score
nardia
Answered
0
Score
Sven
Answered
0
Score
James
Answered
0
Score
Answered
0
Score
Answered
0
Score
Answered
I got the same problem with the 6th generation ipod, broken powerbutton. The little cloth on top of the powerbutton was gone (inside the ipod).
Here is what i did:
I dismanteled it. I used my nails to get a grip around the touchscreen, and then i gently took it out and to the left side. unscrewed the metal plate behind the display.
You dont need to unhook the cables, but you have to move the battery aside so you can get accsess to the cables and buttons. I Removed the black tape first and then i unscrewed the 4 little screws on top and i gently took out the buttons and cables (they are all connected to eachother), so i could take a look at it.
I cut out an little piece of doublesided tape and i folded it once. then i used a needle to place it on top of the powerbutton(the button connected to the cables, because everything is so small. There is a small gasket around the powerbutton, that one i removed completely, cause it caused me alot of trouble. After that took 2 of the 4 screws and mounted it back together, just to test the powerbutton(tes
What i needed to to this operation:
- Good lightening, I used my cellphone cameralight. I placed it on top of a glass, so i got good lightning down towards the ipod.
- Tiny screwdrivers, Star-screwdriver, but you can do it with a flat one too.
- A little piece of doublesided tape and a scissor to cut out the pieces of tape.
- Superglue, to use around the seal of the screen.
- Take good time, this is tiny bits and pieces.
I had to do this operation several times to get it to work.
I was not interested to send it back to the webshop and wait several weeks to get it back.
Im guessing im not the only one having problems with this.
Good luck :)
Benjamin (Flip-Da'Script)
I took mine back to the apple store and met with a genius. They replaced the nano under warranty. My power button stopped working also.
Lynn,
I ended up just going to the store where I bought my iPod and using the warranty to get another one. I think it was just a faulty batch of iPods.
Emily Routh,
My own opinion : these iPod's suck. I have no idea why I bought it. My power button is stuck, there are no games, & I got tired of it a week after i got it. I want top sell it, but since the power button is stuck - I'm out of luck. The ONLY way this iPod will work, is if you get the Apple headphones with the play/pause button. Can i return it in to the Apple store (which is like hours away -__-) for a new one ?
tatianna,
