0
Score
Avatar
tyler
Asked
Ipod is dead it wont charge and i cant put songs on it how do i fix it
History
my Ipod is unrecognized by itunes and therefor it won't charge and i can't reset it. i also can't put songs on it. when i plug it in, it says connect to power and shows the apple sign then shows the front menu then says connect to power how in the world can i fix it?
Edited by: oldturkey03 ( )
mine also same...wat shud i do?
winark,
Post Answer
5
Score
Avatar
rab777hp
13.6k
Answered
Accepted Answer
PermalinkHistory
Most likely a bad battery, get a new one here.
0
Score
Avatar
sbdfhs
Answered
PermalinkHistory
Try a reset. Press centre button and menu. Hold for a few seconds to see if apple comes on screen.
If that doesn't work plug it into a computer via a USB lead to recharge it. Docks and PSU type chargers may not work if it is dead flat.
Update
I am talking from my own experience. I had a dead Nano and it would not charge from a PSU or dock, but did from a computer. Possibly it was because it was not an Apple psu. I would advise anyone with a dead Nano to try recharging from all sources.
Edited by: sbdfhs ( )
sbdfhs, you have it reversed. A computer USB output is no less than 4.75 V and no more than 5.25 V and 500mA. It will NOT charge a battery that is below 2.7V You WILL have to use at least an AC charger since the spces on those are Input 100-240V - 0.15A (0.15A) 50-60hz Output 5V --- 1A So your answer is very misleading. May be an edit would be nice:-)
oldturkey03,
Add Your Answer
