iPhone 3 GS wet with milk and not on
My 3GS 32 GB vibrated and then I noticed there was small amt of milk on the phone.The phone keeps vibrating while screen is black and feel a little heat of the unit. I pressed "home" several times and then saw screen back on with Apple Logo.A few seconds later,the screen black again after I press "home". It repeated two times. In the second time I noticed 5% battery level. Eventually vibration stopped by it own (may be run out of battery).
No sign of life when connected with wall outlet. With USB, it showed "found new device on PC" and then Itune logo appears with "in recovery mode,.. restore" but still not sign on iphone. BLACK.
While open the unit I noticed there was a spot at right edge of the logic board covered with yellowish stuff similar to the leak from a regular old battery.
A little white milk at low left corner of the screen was seen.
The phone has been in this way for three days.
It battery damaged? or motherboard issue?
vibrator issue? connector assembly issue?
Any idea what might happened and how to do with it.
Thank you very much.
