0
Score
Avatar
cory
35
Asked
Won't run on known good battery
History
Hi there,
I have a macbook mid 2007 that shuts down immediately after it is unplugged from AC. I've tried the battery on another machine and it works fine as well as trying a known good battery in this machine.Also I've tried a known good AC adapter. Other things I have done are run the hardware test which shows no errors, reset the smc and Pram, repaired permissions etc. the battery appears normal in the menu bar and says it is fully charged.Also it Appears in system information as normal.coconut battery also appears normal with 275 cycles.I'm hoping the problem lies in the Battery Connector with Sleep Switch and not the logic board. Anyone had any experience with this problem?
One other strange thing is that after unplugging the AC the system shuts down immediately, but once you plug it back in it starts without the power button being pressed.
Edited by
Post Answer
0
Score
Avatar
machead3
12k
Answered
Accepted Answer
PermalinkHistory
Sounds to me like liquid spill behaviors both the sudden shutdown and the automagic startup.
N.
I think you are right. i'll open it up and see if there is any stickiness.anything else to look for? (this is not my macbook)
cory,
Cory could you mark this answered?
machead3,
0
Score
Avatar
Xen
387
Answered
PermalinkHistory
what is the full charge compacity of this battery?
5077 is the full capacity
cory,
0
Score
Avatar
Jethro
133
Answered
PermalinkHistory
Doesn't seem like liquid damage. I have seen this many times, especially in MacBooks. There is a system bad connection between the battery connector and the logic board. On some of the older model MacBook the battery connector would get fried. This would damage both the battery connector and the logic board. I bet if you open the computer and remove the battery connector you will see the corrosion I am talking about. Don't worry this isn't water damage.
You can try to clean off the logic board and replace the battery connector but in the past I have had to replace both the battery connector and the logic board.
Add Your Answer
